Linux v7 client
these are non-oc'd boxen, just factory clocks as it's a OEM server and I can't really tweak it.
Mine are at stock as well, 2.93 with a turbo up to 3.2. No overclocking on an asus Z8NA:mad:
May be worth checking again mid way through the unit and seeing if your tpf's are any better
blah, we had a power blip just after I signed off last night :( didn't catch it until a little bit ago, had to restart the WU :( Oh well, hopefully I'll still make the deadline
20:19:34:WU00:FS00:0xa5:Completed 6460 out of 250000 steps (2%)
20:38:15:WU00:FS00:0xa5:Completed 7500 out of 250000 steps (3%)
21:22:47:WU00:FS00:0xa5:Completed 10000 out of 250000 steps (4%)
22:05:37:WU00:FS00:0xa5:Completed 12500 out of 250000 steps (5%)
22:47:32:WU00:FS00:0xa5:Completed 15000 out of 250000 steps (6%)
23:33:42:WU00:FS00:0xa5:Completed 17500 out of 250000 steps (7%)
Does you server auto-restart when power is back on ? If yes you may want to run v7 as a service, since it would by itself run the core just after reboot, even though no user logged on after reboot.
it was still running but it was in a kernel panic as it lost both primary and secondary power for just a moment (not long enough to power it off, but long enough to panic the OS), didn't notice it until I went to go check on the WU :(
so I guess you could say it was a brown-out, not really power loss
Umm something is wrong somewhere your TPF has almost doubled your current TPF gives you a completion time of 2.94 days which is past the deadline about 18 hrs. and gives you 7689 ppd. chect to see if you have 2 clients running or something else running in the background.
lol yeah I saw that last night, didn't realize there was a second WU running in the background, not sure how but it was. So I killed it and now this is what I'm getting:
******************************** Date: 20/10/12 ********************************
21:19:32:WU00:FS00:0xa5:Completed 110000 out of 250000 steps (44%)
21:49:55:WU00:FS00:0xa5:Completed 112500 out of 250000 steps (45%)
22:20:08:WU00:FS00:0xa5:Completed 115000 out of 250000 steps (46%)
22:50:52:WU00:FS00:0xa5:Completed 117500 out of 250000 steps (47%)
23:21:27:WU00:FS00:0xa5:Completed 120000 out of 250000 steps (48%)
23:52:48:WU00:FS00:0xa5:Completed 122500 out of 250000 steps (49%)
00:23:45:WU00:FS00:0xa5:Completed 125000 out of 250000 steps (50%)
00:54:11:WU00:FS00:0xa5:Completed 127500 out of 250000 steps (51%)
01:24:58:WU00:FS00:0xa5:Completed 130000 out of 250000 steps (52%)
01:55:52:WU00:FS00:0xa5:Completed 132500 out of 250000 steps (53%)
02:26:54:WU00:FS00:0xa5:Completed 135000 out of 250000 steps (54%)
Much better probably will not make the deadline on this one but you should have no problem from here on out. :cool:
