Linux Ubuntu - Wine and Winetricks
Well,
1: I have a norwegian keyboard. And aMSN dosn't seem to support the alot used norwegian letters Æ, Ø and Å.
2: It misses alot of functions I like about the 2009. I even hate the new one and I wont use it.
3: I really don't like the look of the aMSN, I mean, the profilepicture is not even on the right side. Also so is the smilyes wrong...
You could use virtual box. I'm sure its overkill for a single app, but if its already installed, maybe not. You wouldn't need virtual Windows, although you could, but rather another Linux Distro that you know does work.
When Wine doesn't work, Virtual Box usually will. That said, HardForum isn't exactly the best place to get specific wine advice. I would try to start a help topic on the AppDB of wine for this particular program. I doubt anyone else here has bothered setting up Live Messenger on a Linux box before.
If you want windows specific software, why not just use Windows?
IMHO pidgin is a lot better than having 27 IM clients -- one for each network...
If I went into the Windows forum and asked how to use md-raid under win7 home premium and use it for raid, what would people say to me?
I guess it'll just lag down my slow processor.
Well, I'll see and take a look there, may you send the link to that website?
Why not run Windows? I currently do, but Windows XP is on 40% idle...
Linux in the other way, was on 5% with all effects on...
It's a 6,5 year old Dell PC which I use as a secondary PC when I'm ingame etc. So to have the social shit right with me ingame can be very usefull.. :)
VMWare Player running a Windows XP virtual machine in Unity mode.
Strip down the Windows XP install as much as possible and disable as many services as possible. I know it's still a lot of overhead just to run Windows apps, but if you streamline the OS, it shouldn't be too bad.
I never use these out of my webmail accounts, but yahoo was offering to log me into MS Messenger somehow. Maybe there's a Web based equivalent to messenger.
