im apirate
- Apr 3, 2005
Should i go from Windows XP prefesh to Linux i dont know what verison. If someone uses it now, can i have some information, as to I never used it.
ShockTech said:Do you have any REAL reason to do it other than saying "Im running Linux" ?
If not, then dont even bother.
FunkStar said:My advice:
Go to UbuntuLinux.org and download their 'live' CD. This will allow you to run linux without installing it try it out and get used to it. After a while you can download the normal non live version and install it permenantly.
FunkStar said:If you play games, don't use linux cause game makers are idiots at the moment. If you use it for every day things then yes, linux is better. I recommend though, reading a few guides on linux so you can see how it works as opposed to windows. Jumping into Linux cold can be bad if you don't have patience to learn new things and might put you off it. Just stick at it and in the end it pays off.
It's amazing how many people can't grasp this overall concept.smllpx said:Game makers aren't idiots. ~95% computers run windows. Game developers would be pretty stupid if they didn't concentrate their efforts in windows.
