Linux: Project 2665 (1920 Credit) using A1 core now?
capreppy
[H]ard|DCer of the Month - April 2009
Using notfred's Virtual Appliance. Project 2665 (1920 points) had been using A2 cores and were very efficient (~3100 PpD). Now it is using A1 cores and only garnering ~1900 PpD.
Is my memory bad? I thought all Linux 2665's were using A2 cores. Have they always been A1 cores?
There are some 2665 that run on A1 designed for the Win platform.
The assignment server is random and just gives out the next work unit.
Since the Linux Version can run both, it is 50/50 which one you will get.
Right now, I am running project 5102 (3340 points) A1 Core on Lunix .... luck of the draw.
Project 2665 all use A1 core, there is no A2 2665. You may be confusing with 2668/2669, which is true A2 projects or even the initial 2662 (clone of 2665 but for A2).
I guess the days when the Linux client was seeing 90% P2605 WUs are definitely over. :(
I think so. I've not seen a P2605 in a while. I'd sayd 75% 2665 and the remainder as 2668/9.
Xili, thanks for the info. I guess my memory is starting to go :(
