ne0-reloaded
- Jul 1, 2003
I setup a pptp server (poptop) and I'm wondering if I need to configure routing on it. Once I connect, I cannot ping anything; I can't even ping the vpn server. I disabled the firewalls on both sides.
any help would be appreciated.
thanks
edit: here's my config:
CONFIG FILES
SYSTEM SPECS
INSTALLED APPS
It connects fine but I just don't get any connectivity after that. I have mppe installed but not configured so I don't know if that's the problem
thanks
CONFIG FILES
Code:
/etc/pptpd.conf
localip 192.168.1.2
remoteip 192.168.1.10-50
/etc/ppp/options
debug
name 192.168.1.2
auth
require-mschap-v2
proxyarp
/etc/ppp/chap-secrets
billy 192.168.1.2 bob *
SYSTEM SPECS
Code:
2.6.11-1.i369_FC4
Fedora Core 4 (Virtual Machine)
INSTALLED APPS
Code:
ppp-2.4.3-5.fc4
pptpd-1.3.3-1.fc4
dkms-2.0.13-1.rc4
kernel_ppp_mppe-1.0.2-3dkms
