linux/mac help
roftranspo
[H]ard|DCer of the Month - July 2006
Hey...i just got a mac with osx 10.3 and i want to set the folding client to run like a service in windows...any ideas?
At one point back in the day, there used to be an actual OSX service mode installer, but its long since disappeared. http://www.hardfolding.com/index.php?go=48, that guide should give you what you need to know though, not quite an always on service, but the best you can do with a Mac for now.
See...that is for a single user...i want it to be able to load in the background when the system starts...any linux heads want tell me how they can do this on linux since i can pretty much dulicate it on the mac....PLEASE!!!!! Oh yeah...i need to be able to add the -local tag too.
FOR THE HORDE
as root:
edit /etc/rc.d/rc.local
Add your command to this file, example:
./home/user/folding/FAH-Linux.exe -local
save file, reboot.
Another way that I use for a few macs is to set it up as a cron job:
@reboot /Users/username/fah5 -forceasm -advmethods
to edit the crontab type crontab -e
Press insert
type in the command
Press Escape
:w to write the file
:q to quit vi
