Linux Laptop - under $150 with 1080p screen?
What do you guys recommend (used market is totally fine)?
Battery life would be nice but it is low low budget.
Mostly to use for programming + basic tasks. Playing youtube videos would be nice at 1080p.
I seem to see a lot of first gen i5s but not sure what might be a good idea? Maybe atom? Though I want to avoid problems with compatibility in software so mostly x86.
I'd look for a used Dell Latitude, a used HP Elitebook, or a used Lenovo X-series machine if it were me. I'm pretty sure you can find a whole bunch of those kinds of business class machines on eBay nowadays (off-lease hardware) from $150 to $200. Finding one with an actual 1920x1080 resolution display may be a bit challenging because most resellers will charge a slightly higher price for models that have that resolution but you might get lucky.
Of course there are plenty of consumer class machines available that will probably be easy to find and some might even offer that resolution as well but I personally never recommend the shiny plastic crap of consumer class hardware. :D
As for the processor, considering that modern GPUs - even Intel integrated ones if that's what the hardware has - will easily handle playback of YouTube content in 1080p format. Realize that content uploaded to YouTube is compressed before the upload (more often than not) and YouTube compresses it yet again to further reduce bitrate and file size so, it's not as if any video you'll find on YouTube in a 1080p format is going to be anywhere near what the same content directly off a Blu-ray will offer in terms of visual quality and actual bitrate. It's passable, sure, but if your intention is to use a laptop for viewing that kind of material you're already "losing" in the respect that you're working with a small(er) display panel to begin with anywhere from 10" to 17.3" diagonal depending.
It's kinda sorta as ridiculous as people that want to watch 4K video on a smartphone display - yes it can be done I suppose but, why? :D
That's a good point. I just found my core 2 duo macbook pro was struggling with youtube video playback. Maybe there is a way to lock youtube at a lower resolution.
I have a surface pro gen 1 which is amazing little machine for the price, just the keyboard is kind of lacking. If I could get the surface pro in a laptop format for the price surface pro 1's go, that would be amazing.
Honestly, the Thinkpad X60s with core duo, 2gb ram, 80gb I have is pretty awesome, the screen angles are the main downside + dead battery. The feel of this laptop is top notch, so I feel you on the build quality point :)
Thank you for your response, I will keep an eye on those laptops. It seems that either you can get a 1st gen i5 with 1080p or a i5 3rd gen~ with 720p~ for about the price range I quoted. I need to research more how bad the first gen i5 was in terms of power usage / heat.
If you have any specific model number's you trust, let me know.
I need to research chromebook's / atom as I know almost nothing about those.
