ftbusdatia said:I have found that specialized linux distros made for firewalls are awesome, quick, well thought out and just plain work without fuss.
but the amount of bloat-ware in X as well as just about every application seems to kill me.. im all aobut making my system microsoft free, but i wont do it at the expense of taking 2-3 times longer to do my simple day to day crap. for example...
Loading mozilla in Linux on my computer = 10 seconds
Loading mozilla in windows on my computer = 1-3 seconds.
Linux seems to have a great kernel.. seems to run stable.. but im sorry, it just doesnt have its act together. i have to agree with the point made that linux's development track is 10,000 hackers hacking a code to work, 250 people sorting through hacks, passing those hacks into a universal hack, that is officialy developed so its not a hack.
Also, i can rememeber looking through the source code for a kernel about a year ago. I can remember the line commented //* does this belong here? while it may not exist currently in the "kernel" code (look elsewhere you will find crap like that all the time), it did at one point.
Linux is great. No lie. I have a linux box. it protects my windows boxes from attack and makes my internet connection alot quicker.
But if i was to install X on that thing, i would be waiting years and years for anything on that box. Not like i need it, its a box, that has no holes, no external ports open, just a firewall and proxy.
Shame on coders for writing X. Clean it up guys... your code sucks. Why should i have to wait 5 minutes for my CPU to compute how a window will fade out?!?! BS! !$#@^!%$#
While I understand your frustration, it is misplaced in the same way as saying "windows sux" because nero won't work with your burner.
The problems you talk about (windows taking forever to fade, the whole interface feeling klunky) sound more like you don't have the proper video drivers installed. Not that I'm trying to place blame on, or insult you; correctly installing graphics drivers can be a pain in the ass in linux at times.
Again, the only problem I have with your post is the app you blame. Linux is nothing more than the kernel. Just the kernel, not more, not less. Saying that Linux sux because you don't like how slow X is, is just as dumb as saying you don't like windows because 3D studio MAX has a memory leak.
Also, even if you were not having a driver issue, the slowness is unlikely to be the fault of X. Your graphical slowness probably comes from bloated desktop environments like KDE or Gnome, etc. X, by itself, is usually just as fast as windows, possibly a little slower, but only to an extent that you can't usually tell. (This all assumes you have a halfway decent card and the drivers properly installed.)
If you are looking for a solution to the slowness problem (not that you are), try switching to FluxBox, TWM, or one of the lighter window managers. Also be sure to double check your graphics card driver as this is probably why things are running so slow for you.
Firefox load times usually have little dependence on X. And yes, in Linux it does take a while on some boxes. This is because firefox on windows uses a little trick: it loads firefox at boot and then just sits hidden in memory. When you start firefox on a windows box you are not really waiting for firefox to load, just a fraction of it. On a linux box, you usually have to wait for the whole thing to load. Although, linux does have a file cache. Try this: boot to linux, and then see how long firefox takes to load. Then close it, start and time it again. It is usually much faster the second time because all the libraries it uses were already cached. You could argue with me all day, but linux's use of memory for a file cache is better hands down than windows wasting memory by locking firefox libraries in RAM.
Anyways, my firefox pops up in linux before I can count to "1", and takes about the same amount of time in windows.
