linux for my 166MHz 64MB beast
The_Bob
I have a pentuim 166MHz 64MB ram system currently running windows 98. I'd like to install linux but was wondering about what distro I sould go with. Its going to be a internet mashine for my little bro's room. No more waking me up in the m orning :D
is openbox available in DSL ? maybe even icewm or xfce.
it's more about the windowing system when it comes down to it. i'm a bit out of the loop of what the other distros offer, but debian and slack should be able to minimally installed with openbox.
I've installed Debian-sarge in 300 MB with X and Firefox for a kiosk project. That should do it, just add a window manager of your choice.
I honestly wouldn't try running anything more than fluxbox(or one of the other boxes) on that machine. XFCE4 might doable, but you'd have to try it to see how well it runs. I definitely wouldn't run a modern version of gnome or kde with that little memory.
Firefox (especially on sites running Flash) isn't a big fan of 64MB either. I've got a laptop (running Debian... Stable (well, the old stable)) with similar specs and, while it does work, it's not terribly enjoyable.
I've dont much the same on a p166 toughbook with 16 mb ram
debian testing
get the flashblock extension for firefox
only run 1 program at once
use abiword if you need a word proccesor
run xmms for sound not rythmbox
window manager to taste (I *LIKE* fluxbox )
I'll give another vote for DSLinux. Works great from installation(I did it on 2 rigs without config issues), small, fluxbox is quick (you WILL be able to use xfce, but 128mb of ram would be better).
BTW: DSL works fine for me on this: Pentium 90mhz/ 32mb ram/ 850mb hdd/ 1mb on-board video. ;) How that grab ya?
tryed DSL. the live CD won't boot. psot some weird error? burned a second DSL CD and same problem :confused:
I've got a IBM laptop with a Pentium 166 w/256MB of Ram and running Debian Etch with WindowMaker. Not lightning fast but it runs pretty well. XFCE4 runs way too slow on my laptop. For LiveCD's I use DSL, Feather Linux, and Puppy(Run that from my USB key). If you don't care for DSL, I would give Feather a shot.
I've got an old winbook xp5 thats a P133 with 32mb of ram and a 1gig that i'd like it try dsl on, the only problem is it doesn't have a cdrom drive except for in the docking station thats not bootable, it does have an ibm etherjet pcmcia network card.
I was wondering what would be the best way to install on it.
gb4-prolly the above link for smart boot manager. I haven't used it, but it looks good for your needs from the linkage.
I'm about to install dsl on both my Celeron 600 w/64 MB, and my Pentium Pro 200 w/256 MB.
My questions are: Is DSL noticably better than Puppy Linux or Feather? If so, how?
Which X display is the lightest of the light? (Assume I am not skilled enough to go full-cmd line, because I'm not :p )
p.s. I'm not trying to thread jack, it seems to me that my questions are similar to the op and would be helpful for both of us.
The Smart Boot Manager should detect it and work fine. I used it on a p150 Toshiba lappy with no bootable cd-rom, and it got me up and running. I used it to try out some live cd's, and then used it to allow me to install linux to the HDD.
I've never tried Puppy or Feather, but Ive heard a few good reviews of Puppy.
Which X display is the lightest of the light? (Assume I am not skilled enough to go full-cmd line, because I'm not )
Heh....me either, I mix-n-match. I find fluxbox is lightest of the few I've tried.
