If you check my sig (Opteron rig), I just setup a server with some spare parts. The server
has two 10/100mbs NICs. I just installed vmware and I would like to setup a firewall in vmware. How do I go about doing this and if I do set it up this way, can I still do basic file sharing? Also, I'm running a mobo with a VIA chipset. What distros are good and compatible with it? Do note I only have half a gig of ram, so will i have enough? All this thing does is fold and some file sharing. Only uses 186mb on idle.
Thanks!
Thanks!
