Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
The anwser is that you need to use ndiswrapper with your windows driver to get it to work. I believe that the wireless uses the broadcom chipset. You would have to do a lspci command to find out for sure.
