Linux and F@H
Little_Kenny
I know this has been discussed before, but the search function isn't working right now. Are there any distros that work less well with F@H than others. I'm on the brink of jumping into the Linux pond and would rather get started with a distro that will play nice with my obsession/addiction. ;)
Thanks for the help.
Fold On!
Fold On!
I'd like to know myself. I have limited HDD space, so going Linux as opposed to Windows is going to be a must. :) I need to set it up in a headless fashion, get my farm back up to 4 machines (plus my girlfriend's lappy and PC).
Originally posted by inzane123
Not sure about one that doesnt work but mandrake 9.2 is working well.
Great! I was looking at Mandrake.
<bartels&james voice>Thank you for your support.</bartels&james voice>
Fold On!
how do you get it to run?
I installed Mandrake 9.2 last night but I can't figure out how to use the linux console (its an exe?) :confused:
Buy this book: http://www.oreilly.com/catalog/runux4/
Get it from amazon though, it is cheaper. Or if you can find the fourth edition on half.com used then get it there. It is a great book.
