burningrave101
- Sep 9, 2003
http://www.anandtech.com/linux/showdoc.aspx?i=2158&p=1
Test Setup
Conclusion
EM64T seems to be doing very well against AMD's x86-64 in a 64-bit environment. I'm looking forward to seeing some more 64-bit benchmarks once we have some 64-bit games and a 64-bit version of Windows XP next year.
Test Setup
As there may have been a little confusion from the last review, the DDR PC-3500 only runs at 400MHz. The Infineon Registered RDIMMs used on the Xeon runs at slightly high latencies. All memory runs in dual channel configurations. We removed 1 CPU for the tests in this benchmark, but since HyperThreading was enabled, we used the SMP kernel. During the second half of the benchmarks, SMP was disabled and the tests were re-run under the single CPU generic kernel. These are both 64-bit CPUs, and so, all benchmarks are run on 64-bit OSes with 64-bit binaries wherever possible.
Conclusion
Without a doubt, the 3.6GHz Xeon trounces over the Athlon 64 in math-intensive benchmarks. Intel came ahead in every severe benchmark that we could throw at it, particularly during John the Ripper. Even though John uses several different optimizations to generate hashes, in every case, the Athlon chip found itself at least 40% behind. Much of this is likely attributed to the additional math tweaking in the Prescott family core.
