Hey guys, I just picked up a WRT54GL, apparently its just a repackaged WRT54G v4. Anyways, I set it up everything was good, and i decided to try out some dd-wrt fun. Loaded it up with v23, everything works fine after a reset and its smooth.
However, I opened up the wireless settings, put in a WPA protection and started to broadcast. The lappy I'm trying to use to connect to it WILL detect the connection, however, it has 0/5 bars for strength. I know this is incorrect because the router is no more than 2 feet away. So I double click the connection and input the passphrase, and theres no go. The error message is just cannot connect to wireless router.
Trouble shooting: I've disabled protection, reverted back to the original Linksys firmware, reset the router, rebooted my laptop, I even changed channels, without any luck.
Can anyone give me any hints? Im trying not to conclude a hardware problem, but its getting dangerously close
Any ideas would be appreciated, thanks.
