I got a problem that I seem to be stuck on. I have an ADSL modem that uses PPPoE (ZyXEL Prestige 623ME, but I don't expect anyone to know anything about it, cuz it's hard to find info on it), but the way it's set up is it does all the PPPoE for me and even has a built in firewall and all, DHCP server and NAT and everything. I don't really wanna use this firewall cuz I'm gonna use a wireless Router (Linksys WRT54G), but it seems when I turn the firewall shit off on the modem it stops working. So it seems I have to set up my router to work its firewall behind this modem, which is where my question is. I can't seem to be able to get it to work, it worked for a bit but not anymore. When it worked I was just messing around with all the settigns I could think of, like making it act as "router" instead of "gateway", letting it do dynamic routing, then turning that off, and somehow it worked for a bit, then it stopped working, Honestly I didn't really know what I has to set things to, just trying shit. Then it stopped working and I had to reset the router. I tried it again this morning with no luck, basically my router gets an IP from the modem's DHCP, but that's doesn't do anything. If I just connect a Windows XP comp directly, it works okay. Anyone know of a guide that could help me with this, or know how to set this up? Ideally if someone out there knows how to skip past the modem's firewall that would be sweet, cuz I'm worried about setting port forwarding through multiple firewalls, etc, but whatever, one problem at a time. Sorry for the long question, and thanks in advance for any help.
Saa|3
Saa|3
