Hello, my friend has DSL, and its pretty fast. he never lags. however, I have a linksys card, and when i come over, i get sudden random lag spikes regularily. figured it was a driver problem, but vista says i have the best driver... any ideas?
I still think it's the driver, Ive had similar problems, and I thought that really was how unstable wireless was. But I went on the the website and got my specific model # and then downloaded the latest driver, almost no stability issues
Are you using wired or wireless? Also what particular linksys card are you using?
Its possible its a driver issue but their can be many other factors that can cause issues. You could be dropped packets which would cause a lag issue. It could also be a issue with your network card or the system itself.
My machine running vista premium lost connection a few times in 1 day with the same model card
Then Out of 50 sites including ebay and [H] only freetetris.org and bensbargains.net would work
I got pissed off and called linksys they ran me around for a bit asking how long the machine was running the card with vista if I had anything else running on 2.4ghz Blah Blah Blah
After all was said and done I had to update the driver manually
I used a usb hdd on another machine to get the driver update
I had to go into device manager / network adapters/ linksys wireless G pci
Clicked update driver selected the driver file added the new updated driver and I was back online
