WickedAngel
- Sep 4, 2003
I recently purchased a Linksys Wireless-G router and Wireless-G PCI Adapter in the hopes of setting up a small network (I just want basic things like file transfers and internet sharing).
The router itself installed fine. There was no problem and it immediately recognized that the computer was connected to the internet.
The problem came when I tried to install the adapter. First, I put the installation CD in and the system didn't recognize it. That didn't really bother me, so I went into the CD via the Windows Explorer and double-clicked on the setup application. The hourglass shows for a split-second, then nothing happens. I then try to start the program through the Run option in the Start menu. Still doesn't work
I restart the computer and the New Hardware Wizard comes up. It recognizes the PCI card and I choose the drivers located in the disk that wasn't working earlier. It installs the device. It says there is a wireless connection.
I can transfer files between the computers, but I can't get internet sharing to work. Anyone have any suggestions?
