LinkSys 2.4 GHz wireless router question
CruThik
Hey I have a LinkSys 2.4 GHz wireless router, and recently I bought a 2.4 GHz phone handsets which seems to cause my internet to become very slow.
Not only does the internet on my laptop (which has the wireless network card installed in it) become slow, but also the internet on the other three desktops in my house becomes extremely slow. All three of these desktops are connected to the router by ethernet cables.
I was just wondering if there is anyway to fix this problem, or would it be better to just return the 2.4 GHz phone handsets.
You can try moving the channel of the access point/router. That sometimes help. Otherwise, go with 5.8GHz phones or 802.11a.
How would I do that?
The main reason I would like to know is because the 2.4 GHz phone really causes my Xbox to lag when I play on Xbox Live (because my Xbox is also connected to the router via a ethernet cable).
Enter 192.168.1.1 into the address bar and type admin on the password entry screen. Go into wireless options and change the channel to something else and keep trying it until it no longer intefears with the cordless phone.
I see no reason why you couldn't but the Linksys would be the easier solution and sometimes different brand cards/routers don't mesh well.
