Links to DAS enclosures.
Order
I've been looking for a 3u or 4u DAS enclosure. They are definately not hard to find, but I'll be god damned if I can find one that doesn't make you order it with preinstalled drives which make it obscenely expensive. I would like it to be SCSI320--->FC or FC--->FC and have the ability to support two controllers.
I just want to make my storage separate from my other components because of the heat that a drive array will generate. Basically just a storage rack above the system rack.
