Linking Harmony to HTPC?
haxxorboi
I have an HTPC setup and want to get a Harmony remote (520 or 550, IR only) but I can't seem to figure out how people are getting it to work with MCE as there is no IR receiver included. I have used a ATi RF remote for a while, but that's starting to die now, so I figured replacement is in order...
Anyone know of a USB infrared receiver that will work with XP or MCE and a Logitech Harmony remote?
Thanks in advance
That has the ir receiver (though I'm not 100% sure that the Harmony is compatible), but I don't need the remote... Anyone know of where to get JUST a receiver?
It is 100% compatible with the harmony and I spent a month trying to find just the receiver with no luck so I bought the remote + receiver and then bought the MCE keyboard :cool:
Although I got all my MCE stuff off ebay, much cheaper.
i have the harmony 1000, and using the web set up....i was able to get it configured in minutes...it is awesome and works well. btw i am using the receiver that came with my ati 550 theater card.
OK, so just to clarify, the IR receiver that comes with the MCE remote/IR Receiver combo IS both compatible and contained in the Harmony database? Cause if so, I'm ordering that combo off ebay tonight...??
Thanks for the help guys
Yes, I'm using it right now, on the machine in my sig.
