I have a file server I just finished building, as well as my main system, and a tertiary desktop.
The first two have gigabit NICs, the latter has fast ethernet.
I have a gigabit switch that doesn't support trunking - Is it possible to have the third system connect to the server via crossover, and to the switch by standard Cat5e, and then have the two connections trunked into one 200 Mbps connection?
One cable would run between fileserver and client, one between client and switch, one between fileserver and switch.
Is it possible to do this, in software?
