like to know, P6DBS anyone?
xxGriff
I have a Supermicro P6DBS running PII-450x2, i DL the manual, which contains specs for 5 different MoBo's, all BX, Slot 1.
My question is i wanna get faster CPU's, and the literature shows up to 600 PIII ( coppermine-100fsb of course for P6DBS/DGS other models upto 1 gig), but the jumpers on the (my) board clearly allow up to 1gHz. my question is doess anyone have some experience with this model, and possibly know if i can run, let's say PIII-800x2? ultimately i would like 1gHz x 2 but they tend to be pricey, and this is a project for fun, and i don't really have cash to blow.
the latest BIOS is on the board, and is the same BIOS for the other models that Supermicro includes in the manual. as far as i can tell, the board supports voltages for coppermines, and as i said above, it has the jumper switches for up to 100mHz x 10.
I just don't wanna buy 2 procs and have to turn around and sell'em, and then turn around and try and get 2 600's.
any input is appreciated.
If it supports the voltages and will run at the correct bus speed, it sounds like it should be fine. I never had that motherboard though, so I can't give you a definite answer. You might want to ask this question in the multiprocessing forum, they like dual systems over there. :)
