My dad owns a small hotel and wants to light the whole thing up wirelessly. I am not sure which would be the best way to light it up(see diagram). We are using Linksys WRT54g wireless routers with the +7dbi antennas and have flashed the firmware to use the Sveasoft Alchemy firmware. With that we boosted the signal power up to 100-150 to give more power to the antennas. When the router is at the #4 location it pretty much lights up the whole center section and most of the front section. The rear section it will get signal to about the #5 location and drop. What do you guys think the best way to light it up would be? I think the best location for the cable modem would be in #4 since that is the center most point. We also have 2 +18dbi directional antennas which were given to us(similar to this Netgear antenna). Would there be any use in using these? They should be able to transmit and recieve signal? I know that if we could use them, maybe one at #5 and one at #4 we would have a problem with signal? Maybe Im in over my head but I just am not sure whats the best way to light up the rear section. ANY input is much appriciated. Thanks!
Sorry, the entire section is probably about 400ft by 150ft or so guesstimating.
