Libert PSI-XR UPS
Hey all,
I purchased a Libert PSI-XR 1000 last week reconditioned off of ebay with new batteries. Got it home and installed, everything went fine.
At first I noticed that the boot light is on, all the time. Next is what is sort of concerning me... the UPS will switch to battery mode while I still have utility power, and they tries to switch back and forth but seems to have an issue.
I noticed right before that this happened when my AC, which is on a different circuit kicked on. Again the system tried to go back to utility but had the same issue, I shut the AC off and it went directly back to utility with no problem.
When it does this other times, I do not know what else is turned on..
Does this seem like an issue with the UPS or is my wiring in the house just foo-fooed?
EDIT:
Found this in the MultiLink Software: the ups has returned from an abnormal utility input condition
I can see that it is pointing towards utility, which I am hoping for and not a bad unit - just surprised then that my other UPSs don't pick this up...
