LianLi PC-K57 Build
Shata
Its still in its beginning stages right now. Let me know what ya guys think. :D
Plans:
Koolance CPU-370 Liquid Cooling Extreme CPU Block
EK Radeon HD 6970 VGA Liquid Cooling Block
Bitspower 5.25 Bay Reservoir
EK CoolStream 240 XT (2x120 Radiator)
Innovatek Eheim (132.1 GPH)
Lighting, Super quiet fans, sound matting, Custom cut side panel with plexiglass and Everything rubber mounted for vibration.
lots of room in that case, should be easy to setup you wc loop.
if you're not oc'ing, that radiator should be fine. if you are oc'ing, i'd go with a bigger a rad.
if it were me i'd paint the inside of the chassis because of the window. old gunmetal grey isn't exactly pretty.
tho you're cabling is fairly tidy, you might consider doing a custom sleeving job on all your visible cables. that'll be super time consuming however especially if you sleeve each strand individually with 1/8 inch sleeving (not including your sata cables, that'll require 3/8 inch). the up side, a very presentable internals especially with subtle lighting.
anyway that's my 2 cents worth.
That mATX mobo looks like a midget in that case.. I look forward to seeing your build
Wow, excellent job! This seems like just the type of cable management that I like to do. It's nice to see other people who are just as OCD about cable management as I am! :D
