Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
well all three cases can have a lot of crap stuffed into them, and that's exactly what i wanna use it for.. but which is better for cooling, easier to handle, more organized.. etc...?
opinions from anyone who has one of those 3 cases or something similar?
I have a I think its the 7066b and I love it one of the best cases I have worked on in years. Lots of room and with some carefull work you can get most of the cables hidden without having to hack the case up too bad.
I am still working on a few things, in fact I just finished working a 7 port USB 2.0 hub in to the box. Just waiting for the paint to dry up enough to get another coat on it tonight.
I like the look of the PC-V2100 a lot, even more than the older Lian Li's I think. It just looks alot smoother, and I also like the fact that the MB goes in upside down and faces the right. I would like to have a window on the left of my case, and thats something you can do with the PC-V2100. And yes, the powersupply does go on the bottom, and I have heard that the divider thats supposed to help you organize the wire can prevent oversized supplies from fitting correctly.
