Lian-Li Waterblock
Interesting that they're getting in to the market, but unfortunately not an interesting product... there are a ton of options that likely do exactly what it's going to do, as well or better, while looking similar, at a similar or lower price point... and Lian Li, while a fairly good case manufacturer, isn't who I'd go to for WC stuff. That's the domain of EK, AquaComputer and all.
Nickel coated. Is it at all surprising it looks like an EK waterblock in design and mounting bracket?
Wonder if it will have plating issues.
Plus a tin-cobalt layer, apparently.
Nickle plating is fine if done properly, Koolance nickle-plates their stuff for the same reason. I haven't heard of using tin-cobalt plating on a waterblock though.
