Lian Li Warrior
if its like an everyday power supply then it will fit in that case...
"Please Note: The 420 Watt Raidmax Power Supply and 500 Watt Aspire UV Reactive Power Supplies will not fit into this case due to fittings and/or space limitations. Sorry for any inconveniences, you can choose from any of the power supplies below for this case, as they will all fit properly."
You sure? I already have an Enermax 550W http://www.newegg.com/Product/Product.asp?Item=N82E16817103437 so I'm not going to buy one of theirs. And I don't feel like buying the case and noticing it doesn't fit...
So... You're sure?
ive used that case in many builds for my friends. its the same thing, as a regular LL just, modified. i guess the space limitation goes to the top fan. so far all the PSU's ive used fit. and i dont see why there would be a space limitation on a case like that.
Well, alright then... I guess I'll give it a try. What to I have to lose? (besides the 15% restocking fee...)
One more question. Is there anyway to get firewire in one of these cases? I was thinking about getting one of the Audigy2 ZS Platinums with the box that had Firewire on it since I wanted a sound card anyway.... But then I realized that the X-Fi platinum is like what... $20 more? But it doesn't have firewire...
Any other way to get firewire?
Do you mean front firewire, or firewire at all? You could get firewire from a PCI firewire card or if your mobo has a header for firewire and you get the little PCI bracket with it on there.
