Lian Li w/ LCD
linuxfueled
This is two Lian Li PC70B spliced together. The bottom is one case cut to half hight with the front bezel reused.
Table saw and a hack saw:) The LCD fits rite in where the 3 original diskett drive bays are.
The acrylic sides are actually sky blue. However with the black pc parts it appears as a blue smoke color. I will update with better pics when the actual system is installed.
Pictures are really rough.
So pretty much, you built a phase setup, but without the phase unit, and you're using the bottom compartment as a sort of "water keg" setup? Not bad, though I'm not a fan of the acrylic side at all. Personal preference of course.
What's your radiator / fan / pump setup? At least a 3x120 I'd hope?
This was never inteneded to be a phase exchange system. While the case when completed resembles in size and measurments a typical phase system its not. this is 2 Lian Li case with the bottom cut down to match the top with matching front panel. The primary effort was to have enough room for multiple water cooling circuts. I will post more pictures showing the independent systems as the project progresses.
The water cooling system has 2 chrome plated Chevy Chevett heater cores as radiators right now. I had some parts laying around and instead of buying a $300 + cast I thought it would be more fun to build something custom.
The system waiting to go in: (in smaller crappy case right now)
  • P6T Asus v1 Deluxe
  • Gskill 12gigs memory
  • i7 920 @ 4100 Mhz
  • Raid 10 4x 1TB WD FALS Series 32mb cache
  • GTX 260 x2 SLI
  • Power Corsair 850w
