Lian Li V600b, help!
HaX
I'm trying to get the side panels off; however, just by following the directions I can't get the panels off. The installation guide suggest loosening the screws and pull back on the locking mechanism to unlock the panels, then to pull back on the panels. When I unlock the panel locking mechanism the panels just won't budge out.
nvm, the panels were stuck on there pretty tight. I had to lift up pretty hard to get the panels off.. pain in the ass.
haha i had the same problem. It says pull but you have to pull hard.
