Lian Li V600b, CPU Fan?
HaX
I just got a Lian Li V600b to replace an older case, now just wondering .. what cpu fan would be best for this case? I have a Zalman CNPS 9500; however, I don't think that will fit since this case puts the power supply like right over the cpu. (totally poor planning on my part, shame on me :eek: ). I'm a fan of zalman cpu coolers; however, i'm also open to new ideas. So throw the smack down!
im not sure if it will fit but try either the tt golden orb 2 or the blue orb. i had the golden orb for quite a while and cooled well for me.
its alight not the best
if you want the best cooler
get the silverstone nt06 lite(without fan)
and if your powersupply has a 120mm on the bottom it can act as a cpu fan
