i've recently purchased a lian li v600 and i was curious as to anyone thoughts on getting the most efficient airflow out of the case. i'll be mounting the PSU (corsair 620w) in the front, most likely in the 5.25 bay area if there is enough room, to accommodate after market CPU cooler. i'll be running an E6600 CPU and an 8800GTS GPU. i realize in purchasing this case there was potential cooling issues. it already has the 120mm intake in the front and also 120mm exhaust about 1/3 of the way up in the GPU area. i wasn't sure if mounting an exhaust on the top would be better or an exhaust on the back where the PSU would have been housed. maybe either would suffice or both would be better i'm not sure. was thinking of nixing the side exhaust and adding a blowhole also. any inputs or other suggestions would be greatly appreciated..
