vroom_skies
- Sep 25, 2005
Hey you guys. I'm soon going to be ordering my new computer and the case it's going into is going to be the v300b.
I just had a few questions I wanted to get sorted out.
- As of yet i haven't picked a psu, I remember hearing that it had to be shorter that 140mm or something like that. The base minimum I'm looking for would have to be a modular psu with at least 700w with strong 12v rails. if you would be able to recommend some that would be great.
- As of right now the gpu I'm going to be getting is going to be the 8800gtx, unless Nvidia or ATI releases something worth while. Does any one happen to know when the 8900/ 9000 card is going to be released, or any thing on ATI's side?
- In terms of cooling, I'm going to also need some recommendations. I've already chosen case fans, but if anyone has any tips on overall case cooling that would be great. What I am in need of help with is my cpu hs & fan. That will be going on lga775 Q6600.
I really like the concept of this fan http://www.newegg.com/Product/Product.aspx?Item=N82E16835220004 but I heard that it wouldn't fit. i just want to make sure thats true.
Thanks for all the help in advance,
Bob
Bob
