lian-li v300 ?
lord_tris
does anyone have or seen anything about the inside size of the case?
i know that i am going to have to do a little dremel work to get a longer vid card to fit
but what i am looking to do is use my thermalright XP-90 with a panflo fan on it, so does anyone know if that heat sink will fit in the case with no or minimal dremeling?
by the looks of the attached picture, it looks like most sockets would be clear of the drive bays.
if it's not, it looks like the drive bay clearance is as tall as the PCI expansion slot openings on the mobo tray. I'd use that as reference when seeing if a certain HSF would fit.
