Lian Li V2120 Side Panel Design
Nirad9er
I'm thinking about cutting in a design into the side panel of my Lian Li V2120.
Here is the design I came up with. What do you think?
I like it. I still haven't figured out what I will cut into my panels.
I may end up buying a V700 when released before I can decide though.
That should look pretty sick with back lighting. What tools/shop are you going to have to use to do this? Just a dremel?
Im checking to see if my machine shop at work can do it otherwise Im checking around for some laser or water cutting fabricating shops.
