Lian Li V2110 WC
Eibach
Hey so i just ordered the rest of my parts for my new build... let me know what you think or if im missing anything.
Lian Li V2110b
DFI LANPARTY DK P45-T2RS LGA 775 Intel P45
Intel Q6600 - OEM
OCZ Reaper HPC Edition 4GB (2 x 2GB) DDR(800)
620watt Corsair PSU
Samsung 22x DVD player
XFX GTX260
Scythe S-FLEX fans
Water:
Pump:
DD12V-D5 Pump Variable Speed by Laing
Options:
Fitting Size: 1/2" OD Fittings (For 1/2" ID Tubing)​
GPU Block:
DD-Tieton for GTX280/260
Options:
Fitting Size: 1/2 OD for 1/2 ID Tubing
Backside RAM Cooling: Copper Back Plate +$15
PCI Bracket: None
Optional Micro Fitting: No thanks
Video Card to Cool: XFX GTX 260​
CPU Block:
MC-TDX for Intel 775 CPU/Boards
Options:
Top Style: Brass
Fittings: 1/2" OD High Flow​
CPU BackPlate:
Thermalright LGA775 Bolt-Thru-Kit​
Res:
Danger Den Single 5 1/4" Bay Reservoir
Options:
Fitting Size: 1/2" OD Fittings for 1/2" ID Tubing
LED Color: None​
Tubing:
Tygon 3603 Tubing
Options:
Tubing Size: 1/2 Inch ID Tubing 1/8 Inch Wall​
Sleeving Kit:
FrozenCPU Sleeving Kit - Black​
Coolant:
Fluid XP+ Ultra LT with z7 - Non-Conductive 32 oz. Super Liquid Cooling Fluid - Phantom Black​
Rad:
Swiftech MCR320 "Quiet Power" Triple 120mm Radiator - Black (MCR320-QP-K)
Radbox For External Mounting!: Swiftech MCB-120™ "Radbox" - Black
Clamps:
1/2" OD Reusable Clamp - Black​
