Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
HI - sorry if this has been answered already I couldn't particularly find anything via search- anyway - does anyone know of anywhere reputable where I could get hold of this case in the uk?
thanks
I've had one for a couple of months now. I love this case...the side fan is a beautiful thing, keeps my temps low, and the case itself is a beauty to look at.
no - it's just getting hold of them in the uk is seemingly somewhat difficult - and was just wondering how much better it was than the standard plus model which is far more widely available.
Well for all intents and purposes, the regular and Plus II are the same case. The only difference lies in the fact that the Plus II has the side fan that blows heat off your graphics card.
If you can, I would recommend getting the Plus II version due to its cooling system.
If you can't find one in the UK, you could order one from Performance-PCs in the U.S. I live in Canada and they shipped mine to me...I'm fairly certain they ship internationally, but it's expensive
yea I looked there - that's why I'm looking for a more local alternative as the shipping is like 5 jillion dollars. another small question I have - on most web photos of the case I assume they've been taken with flash on - which makes it looks like you can obviously see the silver behind - is it particularly visible in normal light?
cheers
there seem to be maaaany complaints against overclockers re: returns etc. I was going to get it from kustompcs but they only have the plus1. Basically i just wanted to find out if it was necessary to hunt down a plus2, I mean if the plus1 was fine then why the alteration..
