Hey people. Need some advice pronto (yes, yes, yet another
It's about my choice of case for my new rig. It's the monstrous V2000, and from what I gather, it can be rather irritating getting cables and such to reach within.
Here's my question to you: Will my choice in PSU have cables long enough do you think to reach inside a V2000? If I'm right (I'm new to this), the PSU cables need only reach the mobo and its components.
I'm getting a GameXStream 700W, and the cable lengths are as such:
Main ATX cable: 55 cm
2x 4pin AUX connectors: 55 cm
PCI-E connectors: 60 cm
Molex connectors: 110 cm
I'm not concerned about SATA and IDE cables not reaching b/c I'm getting aftermarket SATA2 cables for my HDDs and if my optical drive doesn't reach, I can just move it down in the optical drive cage.
Anyway, the concern here is the length of the PSU's cables...thoughts?
