Lian-Li V2000 Silver Server
catkicker
Been busy with this project for sometime now. Finally getting close to the finish.
The WC'ing loop for the VC's is up and running going to let it run till late tonite. One dripper at one of the rad fittings. Also powered up some of the lites and fans to make sure there all working. Slowly working on cable routing. The UV blue tubing and cables looks awesome with the yellow UV sleeving (at least I think it does LOL
As soon as I put the other radiator in I can finish arranging the tubing so it looks a bit cleaner/tidy.
For the complete step by step view
http://www.ocforums.com/showthread.php?t=470373
if i was you id put a 4 inch uv cathode, or some UV leds in some of the space you have in the 5.25 bay areas to better light everything.
I still have some more UV lites to install.
stormshadow said:
have they come out with the mesh-hole covers for those hard drive coolers yet?
that would help make the look more consistent.
i know they've got the mesh covers for single bays...
maybe a couple of these in front of your hard drive cooler in place of the current grill?
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=210&products_id=3904
I like those. If I had any empty bays I would be useing them. The Lian-Li HD cage that is in the top 2 bays holds 3 HD's and is all one piece, don't think I could use the mesh bay covers
I'll be posting more pics of my progress.
is it possible to remove the grill of your upper intake / hard drive cooler and use the mesh ones instead?
