Lian Li V1200Bplus II
BigBen
im thinking about getting this case, it looks big and roomy. anyone use this case before, if so what do u like/ not like about it?
i have the original plus case which i'm considering modding to a modified version of the plus II case. what do i like about it? well, you mentioned the most important selling point to me. it's roomy! the extra depth of the case over the v1000 makes working inside the beast all that easier. the build quality is typical lian-li. routing cables is relatively easy to do. as for the negative sid eof the case, there is none. some people will mention the lack of a removeable motherboard tray but this case is so roomy that issue is moot. but the case! you'll enjoy it a great deal, i'm sure.
there is one issue for motherboards that have the heatpipe cooling. like the a8n32 deluxe
as the mobo is intended to be mouted upright. but if you have a fan on the chipset area it should be fine
This is more of an mobo design issue than the case :p
agreed. when i initially installed my A8N-SLI Premium, it had stock cooling (heatpipe). After a few hours, things did get a bit flakey. I installed some active cooling on the northbridge and an ASUS heatsink on the mosfets and everything is fine now. i dont' know if that would be an option for the mobo you mentioned, tho.
I concur :D
