All,
The case slated for my new system build right now is a Lian-Li 6070B. My only real concern with it is the 80mm case fans. My concerns are growing and I'm starting to look for a case with 120mm fans.
Of course, my preference is Lian-Li and that's where I start to get confused and a little distressed by what I see. They seem to be changing their design approach on their current range of V cases. PSU at the bottom of the case, upside down mobo and compartmentalized interior. And there's no removal mobo tray either! The upside is that they're attractive and well built (of course) with a fair degree of passive cooling - and the big fans mean that stock performance is decently quiet.
What I cannot, for the life of me, understand is why put the PSU at the bottom? It kills the idea of using the rear fan as a ducted intake to cool the cpu because of heat recycling. And using the PSU as a high mounted rear vent is neutralized seeing as it's at the bottom rather than the top of the case. And if the mobo is mounted high isn't that where warm air will collect? I hope there is a blow hole for a top mounted fan...
So, are Lian-Li a waste of space for cooling performance with 120mm fans? Certainly seems their current design isn't flexible in terms of modability. All opinions welcome
