Lian Li top covers
Eibach
does anyone know if the T-703 will fit with the v2110b??
T-703
it says its only for the PC-A70, PC-A7010 but it looks like it might fit the v2110, also would a MCR320 rad fit with it...
thanks
No, it would not fit. You just have to look at the dimensions of the case to see if it will fit.
The PC-A70 is 220mm W x 590mm D
The PC-V2110 is 210mm W x 620mm D
thanks for ruining my life.... just kiddin lol
