chrisf6969
- Oct 27, 2003
Ok, last X-mas I made my wife the Purple Pimp PC: http://www.hardforum.com/showthread.php?t=855304
This X-mas it was time to revamp my Lian-Li main gamer.
The problem was I had a lot of expensive parts in there that I had upgraded to not that long ago. (2x1Gb OCZ cas2 DDR, P4EE 3.4 s478, etc.) The only upgrade I really wanted was a new videocard. Solution to the problem, get the Albatron PX915P4C Pro. It has s478, DDR & PCIe 16x slot!
Ok now to the old mess: 3.4EE, Abit IC-7, PNY 6800GT, 2x1Gb OCZ DDR, 74Gb Raptor
Planned upgrades, new mobo (Albatron PX915P4C Pro) & new videocard (eVGA 7800GT).
plus I need some major wire management revamping!
1st cut the famous Lian-Li wire management hole.
Next cut the back grill and put a wire grill:
I was thinking about putting the harddrive on the bottom in front of the fans. So I cut apart the standard rack. Drilled holes were the bottom mounts are on a harddrive. I tested it out with the brass motherboard standoffs on the harddrive, then I screw the old Lian-Li plate on to it like a motherboard, and thumb screwed it down. However I didn't like the way it looked, so I put it back under the floppy/mem card reader.
Here's a picture of where I was going to put it.
Next wire everything up and test the new lighting. (change from old crappy red neon, to a blue cold cathode)
All ready, videocard came in. Now I had to wait like a week for my motherboard, DAMN UPS!! 4 business days late!! MF'rs!!
Anyway, it gave me time to wire, rewire, re-ziptie, rewire some more, etc..
Motherboard finally came in!!
The wiring would have looked better, but the Vantec wire sleeving was back-ordered. (at so-trick)
http://www.crowdcontrolusa.com/overclock/shizzy.html <-- screenshots & benchmarks
Current configuration:
Pentium 4 - 3.4EE
eVGA 7800GT 465/1150
OCZ 2x1Gb 3200 2-3-2-5-1T
74GB WD Raptor 10,000rpm HD
NEC 4x2.4x12 DVD+RW
Soundblaster Audigy
Lian-Li PC-60
Thermalright XP-90C
Thermaltake 480W PSU
Combo 3.5": Floppy & 7-in-1 card reader
Blue Cold Cathode, lighted fan, etc.
Logitech MX1000
Sony 21" Trinitron
I'm going to change the red led fan to a blue one.
EDIT: I changed the Tornado (at 5v) on the XP-90c to a blue LED fan.
More pictures next weekend when I change the fans.
Pentium 4 - 3.4EE
NEC 4x2.4x12 DVD+RW
Soundblaster Audigy
Lian-Li PC-60
Thermalright XP-90C
Logitech MX1000
Sony 21" Trinitron
