Lian Li PC777
jstenuf
Does anyone know if a PC Power and Cooling 850 will fit
into tthis case?
mashie said:
The 700W PSU I have in my PC-777B is of normal size and fit easily. I don't know how big the P&PC 850W is.
Thanks for the reply.
The 850 is 230mmL x 150mmW x 86mmH If my conversion math is correct it is : 9.055" L x 5.95" W x 3.39"H. Do you case specs give
dimensions for the power supply slot? The 9.055 inch length may be the problem area.
i want to say thanks too. i love seeing it when somebody asks a question and gets an answer. kudos to both. keep posting.
from mashie none the less
