Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
In a PC70/71/75 can you fit a 2x80mm res in the spot above the PSU? I'm asking because I wanna delve into WC and I wanna buy a new case so I'm thinking about doing it all at once. Thanks
I'm not sure, but get the dimensions and just measure it out, make sure you know where you want everything to go before you start ordering parts... and I would not recommend a 2x80mm res, but it's your choice.
