Lian Li PC61 mobo try cut wrong?
LiquidX
I just bought a PC61 and after looking over it for a couple hours and trying another case I have come to the conclusion the mobo tray is cut wrong. No card I put in the AGP or PCI slot will seat firmly. The tray it seems brings the mobo down to low so it doesn't having any clearence to fully seat. I would have to bend my cards for it to fit which I wont do. Anyone have any ideas or had this problem? WTF over a $100 for this case and I cant fit my cards in it. Is it possible to RMA case?
netcoord said:
taller standoffs?
Ive never encountered this problem make sure ur seating the cards correctly....if u still have problems contact the place or person u purchased it from
It turns out that problem is that I am an idiot. I put in the clip and the instructions said wait for the snap. Well they did snap so I thought they went as for as they could go. After calling up for a RMA which I got and looking over that case again I just couldnt let if go. So I tried again and looked on th net for pictures and notice the clips had to be pushed all way up. Man what a good looking case and you can pretty mush hide all teh wires with ease. Still had to bend my sound card but it fites all the way down now. Oops! :p
Dang Dood, I have 3 Lian Li's and I dont know what everybody is talking about, that things dont line up. I even have a mac motherboard in one of the cases and everything lines up. The much maligned clips are a little tricky, but not that tricky.....
I've NEVER had any real issues with either of my Lian-Li PC6x cases I've owned. You also have to take into account though that very few cases are actually built 100% perfectly anyways.....just my opinion anyways.
