Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I would like to remove those stock fan out and replace them with Panaflow or Suno fan. Anyways, how do you remove those 4 plastic rivits? Do I squeez with a needle nose plier?
on the inside of the case is the end of the pin you insert into the other part (it's sort of like those plastic case feet). Push the pin up so you can grab it from the outside. Once the pin is out the other part should slide out pretty easily.
