I'm considering on purchasing the PC-V1000Z. I just want to find out a few things.
1. The height of the case is 490mm, but is that with the caster wheels? Anyways I would like to remove them and install regular feet. Would I have to drill anything or will they just screw in. Any suggestions on what feet?
2. How is the cooling with this case? It only has 2 fans + the VGA fan which I'm thinking of taking out. It just doesn't look right in front of the window.
3. I would like to run a water cooling setup one day. Is this a good case for that? What water setup would you recommend for this particular case?
4. I have read that some hardware is missing with these cases. Has this been sorted out by Lian-Li?
If anyone has this case can you post pics especially if it's water cooled.
Thanks
Thanks
