Lian Li PC-Q20 Mod Case
Hi all, thought I would share some pictures of my PC-Q20. I havent done any serious render sessions yet, but I've been using the case for about 2 months with no problems so far.
Why such a large case? Will you put a GPU inside, a bigger CPU cooler, more drives?
Yes I am planning to put a GPU inside, but I dont have much need for one at the moment. I cut the back hole bigger to fit a dual slot card.
It is also my plan to fit a larger CPU heatsink later on. But for my current CPU the 120mm fan and that small heatsink are working well enough.
It's a cool looking case
Wow, that looks great. I'm waiting for a PC-Q20 to arrive and I'm starting to think putting a fan opposite the mobo like you've done would be a really good idea - of course this is only possible if you've used a slim PSU... What PSU did you use here?
Hey! Nice mods. Been hacking my White Q20 for a few months now. About ready to mod it to fit a 2 slot GPU. Currently rocking a 1050 Ti Mini.
Should have my side panel window done tonight (acrylic and thumb screws).
Currently rocking 2 120mm Scythe fans (1 intake 1 exhaust) and 2 40mm Noctuas as exhaust.
Hey there... Any updates to your Q20 build? Currently modding mine now.
