Notes so far..
For some reason the fan I added to the bottom makes noice
(Noctua NF-P14s redux-1200) In the front is a PWM version parrall with the stock intel CPU cooler, no sound other than usual air movement.
Bottom feet seem small, looking at the pictures again they are obviously smaller than most other of their cases, or the placement makes it look like that.
I'm happy with the 5.25 bay, but its a rather expensive route to add an Icy dock for drives and slim odd. I may add a switch on the back for the tiny fan inside, so far I only have a SSD in there with the OS, but it will be moved to the bottom with velco or something.
The Silverstone sfx-l drive with the short flat cables seems perfect for a case like this, except the double brackets.
